power window relay failure
6:57 AM
usa
Where can one find a power window relay for a Cordoba/Charger? Auto parts stores don't even list one and neither do old Chrysler parts books. No part listed for 2926 433. NAPA was close by picture but w/o attached strap to slip into slot cast into firewall to engine compatment wire harness connector leaving it hanging to be kicked around everytime I apply the brakes. Are these available or do I jumper wire it?
Are you talking about the window switch on the door?
No. But I could use that also. Mine is fairly loose. I'll try an autoparts HELP area. I once got a replacement Duster window crank for a couple of dollars that was identical to the orginal.
What I need is the relay that is held to the firewall wire harness connector. One 3 wire connector and a 1 wire connector. One is black with blue stripe hot. Three blade connector: black ground, red hot, 10 guage? tan goes to door window switch. That's what I can't find. Jump red to tan and the window switch works.
Thanks for the information. Pictures would help. I believe the description at dpmotorparts is correct. The part number helps though. I can go back to a dealer with that number and maybe locate a picture and NS1 availability somewhere in the country.
Thanks for the reference picture. It's not that good. My clip is bent back the other way and it attaches to the fiewall wiring connector on an X/B body. I can't tell how those blades are lined up with that picture. The three pin doesn't look quite right but I guess I'll find out the hard way as I've already bought one of the last four available from a dealer. I can't imagine how this erlectrical part would differ between a Volare/Aspen and the Cordoba/Charger. A power window motor is a power window motor.
Part number 3879696 works just fine for the B/X body. The clip is half the width and aimed 45 degrees off but it's the same relay doing the job, hopefully forever.
3879696 has a casting # of 3747159 on it and it fits 1982-88 M Body (RWD) cars. I have one NOS. It may fit or supersede other models. You can PM me for details.
I'm sure it's probably too late, but if you or anyone else still needs the part you originally asked for (power window relay, part #2926433), I have one in good used condition. Based on the scarcity and what I think I might get on eBay, I would sell it for $20 plus a few bucks for shipping. Not sure when I acquired this, I'm going through various parts I have from vehicles that were being parted out, but have no reason to think there's anything wrong with it whatsoever, it's not my habit to keep bad parts around. :O) I'd also be happy to do resistance tests with my multimeter before shipping it, if anyone knows what the correct readings should be. Just let me know if anyone out there needs it... thanks.
Greetings, I posted further down on this thread, but didn't respond to you directly, so please see that post, and here is a photo of the same part I have (2926433), if by chance you still need it. The eBay part isn't mine, I'm just showing you the photo so you'll see what I have. I'm brand new here, so hopefully I'm doing this right.http://www.ebay.com/itm/1969-1974-C...834-/251855102363?hash=item3aa3bbe19b&vxp=mtr
