Pulleys and hardware for 69 Satellite with air and PS
canblue
1:43 AM
Ontario, Canada
My friend has a 69 Plymouth Satellite Mod Top. We are trying to install the AC, PS, alternator and water pump. We are having problems with brackets and getting things to line up. Anyone have or willing to provide some closeup pictures of these components installed to help us figure out where our problems are. The crank pulley has 4 grooves. What components go on what pulley groove. Any assistance greatly appreciated. This is for a 383 with factory air.
This is some info I got from Bouchillon:
As per the instructions, If you Have our 4700 bracket (not 7400) , it is designed to work with the 4 groove crankshaft pulley (BPE4013) and the 2 groove water pump pulley (BPE4016). The 2 inner grooves on the crank drive the 2 belts that would go around the a/c compressor and alternator. The 3rd groove out aligns with the inner groove on the water pump pulley and a power steering pump if you had power steering. The outer groove on the crank and the water pump aligns with an Idler Chrysler used on all A/C Big Block Engine.... a single belt went around the idler, crank and water pump and you adjusted the idler to tension the belt. We do not offer that Idler assembly but it can be found on most all older big block Chrysler A/C Engines. We do offer the replacement pulley for that idler assembly.
Most all applications utilize power steering , so we generally do not use the 4th groove/belt out that would have the idler position
Randy Bouchillon
Bouchillon Performance Engineering
Randy Bouchillon
Thanks for the input.
