Pulls to the Right
Dobaroy
9:24 PM
Ontario, Canada
Our '75 Charger pulls to the right constantly. Had an alignment done today and it made no difference. Jacked up the right side and that wheel runs free. Any suggestions would be welcome.
Swap front tires left side to right side and vice versa. See what that does. Who did the alignment? Did they set the toe and let it go? Did you get the printout?
It was tires. Every time for me. Tire looked good, bad belt.
Thanks for the replies. Don't have much faith in the alignment that was done, no printout. Actually we took the Cragers off and put a different set of front wheels on, same thing. But in the past we did have success changing the tires on a different vehicle, that is a good idea. About the piston hanging up in the caliper . . . think maybe we are just gonna swap the whole caliper. Will keep you posted.
Swapped the caliper, no change, it's exactly the same. If anybody has any other ideas, it would be really appreciated.
Would need to see the alignment measurements. Until we know for sure that the alignment is right there is no sense in trying to diagnose any more. You said you are not confident in it. Then neither am I
do the wheels look like they are leaning? take a tape measure and measure the toe, its really easy to do. if the calipers and tires didn't do anything then it has to be something in the alignment unless the car is bent. I would take it back and tell them to fix it right
you should have no more than 1/8 of an inch toe out.
