push button 727A small blocks
sdgodwin
7:10 PM
Maryland
leaking from the speedometer cable. Any suggestions' as to fix.
Steve from Calvert
Steve
As I remember there is a rubber seal right on the end of the speedo/pinion assembly. If you can't find one, I am sure I can find one in an old soft kit for 727 that I saved.
Tom
Is it leaking from the cable end where it goes into the tail shaft or the cable housing it self? If it's the housing you'll have to replace it! If not then just replace the o-ring as stated in the other message!
welcome to FBBO
