Push button selector/assembly removal
Anselmi
11:40 AM
Helsinki
1963 Fury.... What is the best way to remove the push button assembly from the dash? Park lever is lose and pushing the buttons doesn't affect anything... :sign12:
you will need to remove tha dash cluster to gain access.If the buttoms are not working,the clip may have fallen off that hols the selector cable.
just climb under the dash and tighten up the box,it has a few screws holding it in. no big deal a 10 minute job. i've been under there a thousand times . no need to remove the dash.
I'm lusting over that clock in your cluster.... Wonder if it would interchange to a 65 Coronet....? Looks to be similar in size.​
