cadjaw55
i recently replaced the valve seals on my 64 318 poly. what is the correct way to adjust the push rods. they had to be removed to rotate the rocker arms up to get at the seals. i was told "not to tight, not to loose!" i have gone through the manual and did not find much info. any advice is welcome!
thank you kindly
cmj
thank you kindly
cmj
