Like I said....these areas are NEVER evened out at the factory.....that is why the extension sticks out further than the quarter panel or visa versa. I never said "fill in" the inside....I said "skim" the outside transition and re-create the groove again, so the piece IS removable like it should be...maybe 1/16" at the most. My point was, there is. such a small edge all the way around that piece, (the part that butts against the quarter panel), there is no way to keep water from getting between the two and rusting out the metal end piece of each quarter panel....already had to cut out and replace both sides....welded in place, just to clarify....no filler inside...let me repeat, NO FILLER ON THE INSIDE BETWEEN QUARTER PANEL AND EXTENSION CAPS..which is why my original question was whether or not a gasket or seal existed, to keep moisture out, even though I did not find one upon disassembly....I wanted to be sure, since 2nd generation Chargers DO have seals...merely wanted to do the right thing. Had no idea by merely mentioning the word "filler", it would make anyone think I would gob a bunch of filler inside and all over it. Not at all what I said, nor would I advocate that.
The factory also never got the gaps around doors and body panels even....doesn't make it "wrong", to fix those too. The point of filler, ANYWHERE on a vehicle, is to fix factory imperfections.....not to fill dents, gaps, and holes. It does have its place....not just in "body shops" either. 9 out of 10 top restoration shops in the world do not paint a
vehicle until it has been skim coated with filler, numerous coats of high build primer, and block sand numerous times.....standard procedure for a GOOD paint job....if all I wanted was a "run of the mill" hackjob re-paint, I wouldn't be going to all this trouble.
Thought I should clarify something in my last statement...when I mentioned "fixing" factory gaps around doors and body panels, I DID NOT mean fix them by using bodyfiller....don't want that to get misinterprated. I obviously meant "adjust" them until the gaps are even. Lol
