the Beast
Hi
In the process of working on the brakes for my 64 dodge 440.
I removed the left rear drum quite easily (seems to be traditional brake/hub setup. The passenger side rear seems to be original drum with the key and tapered axle. Having problems removing.
Is it easy to make the passenger side rear the same as the drivers side?
I'm new to auto repair and can use some advice concerning the pros/cons for different axle/hub types.
thanks
thanks
