Rear seat
Get on the floor on your knees in the front of the rear seat. Use the front seat for leverage
Use your knees to push the bottom of the frame.
Gently thump with open palm in an upwards direction. Seat should release from the lower hooks.
Make sure you remove the armrests first.
Thete are 2 hooks on the floor board, under the seat bottom, toward the front. The seat frame catches on them. Push the seat bottom towatd the rear of the car to unhook it.
@steve from staten island - when the seat is eventually out - check the welds on the rod that locks into the hooks on the floor.
Also check that the hooks are straightened to their correct shape before re-inserting the seat. Tapered inwards...not crushed etc :)
Not exact application, but all the key points are here, and the little brackets are both similar, and in a similar location;
HTH, Lefty71
