rear swap
hacksaw
3:17 PM
hopewell PA
what rearend without that stupid hub will swap into a 62 dart ??
The 1965 models did away with that, right?
I thought all B bodies from 1962-70 had the same 44” spacing on the spring pads.
The 68-70 models was the widest axle of the 62-70 year range.
Short answer?
A 65-70 should fit but tire clearance may be an issue if you use the wider 68-70 axle.
