Rear tire rotation ?
Randy73
12:55 AM
Florida
Was bleeding my brakes after replacing the M/C and jacked up the rear, took off the right rear and bled the brakes. While doing a check of the brakes I turned the axle both forward and backward a fill rotation each way.
Now do I have a problem or is this just a sign the rearend is not a sure-grip?
Not really sure I understand the question. So your saying that when you rotated the tires on the axle one tire rotated clockwise while the other went counter-clockwise? If that is the case you do not have a sure-grip. Sure-grips will rotate the tires in the same direction.
When I was tired, it made sense.
With drivers side tire on the ground and passenger side up, I could turn the pass. side either way with little effort.
So is this something to worry about or did I just confirm that I do not have a suregrip rearend?
Nothing to worry about, you just have an open or non sure-grip rearend.
Or, if you are supposed to have a SureGrip and it's doing that....it means it's worn out. Question is, are you supposed to have a SureGrip?
