FOR SALE REBUILT 413 & TRANS
gnxjohn
5:42 AM
North Ridgeville Ohio
Feedback: 3 / 0 / 0
1973 Rebuilt 413 block 030 over forged piston, forged steel crank ,reconditioned stock rods, balanced rotating assembly, Aluminum stealth heads, Aluminum water pump housing, 7 quart Milodon oil pan, Hughes 490 cam, New 770 Holley street avenger carb. Edelbrock RRM Intake,Electronic distributor, Motor Complete with rebuilt 727 with shift kit, Hughes 2500 converter, Motor & Trans.has 130 miles on them, Still in car at this time can hear run, 70 Lbs oil pressure when hot at idle. Being sold Carb to Pan with Trans.$4,950.
SOLD
SOLD 1973 Rebuilt 413 block 030 over forged piston, forged steel crank ,reconditioned stock rods, balanced rotating assembly, Aluminum stealth heads, Aluminum water pump housing, 7 quart Milodon oil pan, Hughes 490 cam, New 770 Holley street avenger carb. Edelbrock RRM Intake,Electronic distributor, Motor Complete with rebuilt 727 with shift kit, Hughes 2500 converter, Motor & Trans.has 130 miles on them, Still in car at this time can hear run, 70 Lbs oil pressure when hot at idle. Being sold Carb to Pan with Trans.$4,550. SOLD
