FOR SALE Rebuilt Mopar 360 and 727 Transmission
Scooby67
9:33 AM
Wolcott, CT
Feedback: +0 / =0 / -0
360 block, new cam bearings and freeze plugs. Stock crank, reconditioned rods, moly rings, tri metal bearings. Keith Black KB107hypereutectic pistons, High volume oil pump.
Edelbrock PerformerRPM aluminum cylinder heads(#60779), 63 cc chambers, stock roller and push rod setup. Edelbrock Performerdual plane intake, Comp Cams hydraulic .525 lift, 275/287 duration cam. Double roller timing set, balancer, water pump, electronic distributor, Rear sump oil pan installed. A center sump is included.
10.5:1 compression ratio, 410 hp with 420 lb/ft torque.
Rebuilt 727 Torqueflite transmission with 2500 stall converter.
Waterbury, CT
$4500 firm. Joe
