Remote starter
pedal2themetal
2:18 AM
Idaho
HI,
Where do I hook up a remote starter to turn the motor for inspection of valve train. I see a connection block on the firewall but don't know which wires?? Oh 1975 Fury.
Do you see a relay like this probably near the brake booster? Hook the remote to the two large posts.
HI,
Connect the remote starter switch to the battery (BAT) and solenoid (SOL) on Chrysler starter relays, as shown in the following images and text.
Remote starter switch connection for 1975 Fury, and most other 1962 - 1975 domestic rear wheel drive cars:
Most relays have similar terminals with some variations in mounting across years and models, including 1969 and earlier with the ground (G) terminal attached to the relay case.
Remote starter switch connection for 1976 - 1978 domestic rear wheel drive cars:
Remote starter switch connection for 1979 - 1987 domestic rear wheel drive cars:
I was wrong, that stud on the relay is hot to the battery. For whatever reason, I have always just connected to the battery.
