Restoring my steering column questions coupler
northeastmoparnet
9:08 PM
boston
Doing a resto on the steering column and I lost the screw that holds the directional arm to the new turn signal switch I installed. I was wondering if anyone on here knew what type and size? Also, is there somebody who just sells the spring that goes inside the column joint to hold those two shoes inside the steering shaft swivel?
I might have you covered on both .
Can ck tonite
