retaining clips
happyjackdaddy54
10:38 AM
ohio
What is every one using to secure the side trim on 64 Fury HT? Its the last thing I need
I bought the replacement clips for my 64' Polara ( different then yours) and they were junk. Clips were too narrow to hold the trim correctly. I ended up using Auveco #19378 cut to fit metal clips with 10-24 threads, worked perfectly. On the narrower 1/2" wide trim i used #19626 and modified them by cutting off the wire and looped wire retainer section which makes them exactly 1/2". You can cut them with a pair of side cutters. If i remember correctly i bought both clips off of ebay or Amazon
THX for the info
