SOLD Rev Limiter Pertronix 600 $85.00 Canton Ohio Will Ship
padam
10:18 PM
Canton, OH
Pertronix Ignition Products
Digital Rev Limiter
Part Number 600
$85 + shipping
Canton, OH 44709
I used this on my Charger for 2 seasons. I ran it with an orange box system.
I only removed it because I switched to an MSD with a 2 Step rev limiter.
This unit is in excellent condition and functions as it should.
There are a couple of light scratches on the black label on the face, and screw marks on the mounting flange.
Other than that it looks new.
These are $159 at Summit, but seem to be out of stock at this time.
It will fit in a Priority Mail small flat rate box, so $10 shipping.
Other services would be by weight at 1 lb from 44709
Product Info:
Digital microcontroller based unit provides greater accuracy (+/-0.01%) over analog systems.
Easy to use rotary switches permit settings with a resolution of 100 RPMs.
Tachometer output with TTL interface and near 50% duty cycle make our limiters compatible with most modern tachometers.
Reverse voltage protection.
Conformal coated surface mount PCB for reliability .
