WTB RH Vent window bracket
mpro69rr
3:22 PM
Florida
Feedback: +1 / =0 / -0
Hi Guys, Looking for a RH vent window bracket (with nuts if possible), see pic below. This is for a 1969 Roadrunner. Thanks!
Dont know if you knew this but the hole from the trunk latch where the pin comes in to turn arround is made out of aluminium, so if you put the whole part into acid to derust it, it attacks the aluminium. The zinc electrolyt also. So make sure that the part does not break. Did you use a alkali or acid elctrolyt?
I have this one and misc parts if you are still looking.
