SOLD Right Stuff B-Body front brake disc conversion
mpro69rr
1:17 PM
Florida
Feedback: 1 / 0 / 0
Right Stuff B-Body front brake disc conversion. Never installed,new, includes all hardware to do front disc brake conversion except the power booster and master cylinder. Single piston calipers, two extra long brake lines so you can place the calipers on the rear of the disc (if placed on front you hit the sway bar). Rotors and spindles. Please see https://www.getdiscbrakes.com/ for pictures, its the basic conversion. $350 or best offer +Shipping from Florida. I'm getting a new K member with coil overs and I will not be able to use this brake kit because it requires a brake kit that uses the Mustang II spindles.
could you post a part number please, thank you !!
The number is MDC62DC except it doesn't come with the brake booster, master cylinder and brake adjust valve. I'm using those 3 things. I'm getting a new K member with coil overs and I will not be able to use this brake kit because it requires a brake kit that uses the Mustang II spindles.
Im interested, can you get a quote for shipping please to a business address in compton ca 90220
That's going to be expensive to CA. I'll try and get you a quote tomorrow. The calipers, spindles and rotors are heavy.
