roller rockers wtb
I have a set of SS 1.5 rockers only $200 plus shipping, I went with 1.6 ratio
Brian
I like the Mancini brand ( basically restarted Harland Sharps). Good set and Mancini is good to work with as a company.
Mike
Mike
Mancini is a good company. When I was looking for rockers I talked to Harland Sharp about the Mancini rockers (that they make) and they informed me that they are BB Chevy rockers fitted for the shaft mount and that they we not a true 1.5. They are all aluminum, no bearing or bushing on the shaft. They say that they hold up fine but the ratio bothered me seeing how it's hard to adjust rocker to stem contact on the shaft mounts and I already had a set that were not a true 1.5 and they fit horrible. I bought Comp Cams Magnum rockers, put a little presion blue on the stem cranked it over and walla perfect contact pattern. I've never used the Mancini rockers they may be great just really check the rocker tip to valve stem contact, should be in the center of the stem at half lift. Good Luck
comp doesnt list those on their website for a bb chrysler, were did you find them?
