rough idel
snake
10:07 PM
canada
Hey guys what causes rough idel in a camshaft is it lift,or duration.I would like to pic a cam for my 318 with a bit of a rough idel and some more lift with out having to change my push rods and going to adjustable rockers,so i would like to use stock valve train.Its a 318 with headers, single plane intake 3000 stall with 355 gears ,stock compression.Any tips.:grin:
Interesting no one wants to try.
comps got a tech line toll free tht could hook ya up spot on.
I have a 318 in my '74. I ended up going with the Comp Thumpr series. I has a pretty choppy idle and it still does well with power brakes and A/C. Overall it sounds awesome!
Was it a stright slide in,did you have change your lifters and rockers.
A lot of overlap (short lobe center) is a big contributor to the rough idle, but that together with a low CR engine you won't like the result.
Well the plan is break it in the 318 and than install it in my 360 this winter,however it has a tick noise some has said i need different push rods and adjustable rockers.any thoughts
