SB vs BB power steering pump?
Moms68
8:12 AM
Central CT
In the process of doing a big block transplant into my '68 b body. The original SB pump is in good shape with no issues, so can it be used with different brackets?
IMO.....YES....using the correct mounting brackets to insure the crankshaft drive sheave centerline lines up with pump's drive sheave centerline plus the required high pressure and return hoses......other's may be able to note which brackets to use.....
BOB RENTON
