Shifter Outer Trim Plate Changeout
71SandbugCharger
12:41 PM
California
Do I drill these out to change the top plate out, or is there a better way?
I used a small stone on a Dremel tool to grind off the heads on mine. If you're patient and slow, you can get the off cleanly.
I used a very small bit to drill out the 'spot welds' on the raised cup that houses the light, and then gently pried up around the welds to pop them free.
I can show you pictures of the parts separated if you'd like.
I found rust on the plate after I got it all apart. Should I spray paint it?
Year One, 30% off until Monday Night 8th) 12 midnight. Use "MOPAR" for the discount. Their catalog has unmarked and marked "Slapstick ".
