Small Block Water Neck Spacer
hunterrocks24
6:10 PM
Wisconsin
Hello Everyone!
I currently have a 318 with a edelbrock LD340 intake on it. It has a port for a 1/8 npt gauge which I tried to make a t for. One side analog gauge (factory) and the mechanical gauge. That doesn't seem to be working. I see people have suggested using a water neck spacer but am seeing only small block chevy, big block chevy, and big block mopar. Any ideas or something that worked for you in the past? Thanks everybody!
The Sb mopar are the same water neck as a bb mopar so see if it will clear your intake runners.
I grabbed one from Summit Racing, a company called Joes racing products… or something to that effect.
Is the distributer in the front or back....?
Sorry, wrong post for this response
Thank you everyone. I ended up buying a small block chevy riser for the neck. Let's hope for no leaks! Thanks guys! :)
