themechanic
Oklahoma is OK
- 7:15 PM
- Nov 11, 2012
- Moore, Oklahoma
This is a boosted front disc/rear drum system properly bled (bench bled MC then 4 wheels). I used the tool to set the booster push rod length. I have the proper power brake pedal linkage. I have the proper disc/drum distribution block. All brake components are new with zero leaks. The car will stop only when the pedal reaches the floor.
What's the solution?
