WTB Speedo drive
Are you talking about the cable that drives it or, the adapter that holds the speedo pinion gear that goes into the transmission?
See hyde-park's question above.....what part do you need? If it is the gear itself, you'll need to know the outside diameter of your rear tires and your rear end gear ratio in order to get the correct gear.
