Starter for 1970 GTX 440
Factory starter? Yup. A starter for a high performance car might be a higher horse power starter so the body of the starter might be a bit longer but never had a problem with the shorter starters with the higher compression engines.
Hey Vaanth, why did you delete that chart??
Yeah, had it long enough to date two of the rebuilt starters that I have, but got what I needed.
Thank you!
Will a Starter for - 1965-1968, 1970-1974 Plymouth Satellite work for my GTX?​
The listed Chrysler starters will fit the 1970 GTX with a 440, with some exceptions such as the direct drive starters used on a slant six with heavy duty manual transmission or 1966 - 1968 426 Hemi with manual transmission.
The following table lists the Chrysler gear reduction part numbers, variations, and production dates. These starters all interchange physically with different internal electrical and mechanical parameters, performance, and one external size difference. The listing is for original starters as originally built. Remanufactured starters can have mixed components, but the fit and interchange is the same. For more information, see Chrysler Gear Reduction Starters.
Part NumberProductionHorsepowerField CoilsBrush Plate & SolenoidNew Changes & NotesLester Number
20951501962 - 19691.3Small; three series and one shuntCaptive with sealantIntroduced in production.3250
20985001963 - 1969 1701.3Small; four seriesCaptive with sealantHigher cranking speed.3250
28755601970 - 1972
Some 1969 after 4/1/1969
1.3Small; three series and one shuntTwo-bolt, rubber-gasketMiddle bushing removed. Replaces 2095150.3250
36566501973 models - January 19731.3Small; four seriesTwo-bolt, rubber-gasketReplaces 2098500.3250
3656575From January 1973 - 12/18/1974; initially on 360, 400, 4401.5Large; four series parallelTwo-bolt, rubber-gasketLarge field coils, higher speed (~33% faster), longer spindown.3257
37552501975 - 19771.8Larger; four series parallelTwo-bolt, rubber-gasketLonger field housing & armature, 2:1 reduction, higher speed, shorter spindown, shock absorbing clutch.3257
375590012/19/1973 - 19781.5Large; four seriesTwo-bolt, rubber-gasketShock absorbing clutch.3257
40919501978 - 19801.8Larger; four series parallelTwo-bolt, rubber-gasketReplaces 3755250.3259
40919751979 - 19801.5Large; four series parallelTwo-bolt, rubber-gasketReplaces 3755900.3257
411185519801.5Large; four series parallelTwo-bolt, rubber-gasketNew number, replaces earlier 1.5hp starters.3257
411186019801.8Larger; four series parallelTwo-bolt, rubber-gasketNew number, replaces earlier 1.8hp starters.3259
41453591981 - 19871.5Large; four series parallelTwo-bolt, rubber-gasketNew number, replaces earlier 1.5hp starters. May be stamped with 4111855.3257
41453601981 - 19871.8Larger; four series parallelTwo-bolt, rubber-gasketNew number, replaces earlier 1.8hp starters.3259
Thanks so much, this is the one I went with.
