Steering wheel adapter
MikeyT
2:33 PM
Wisconsin
Hi all,
I was wondering does anyone make a steering wheel adapter for aftermarket steering wheels for telescoping and tilt steering columns?
mike
I've been trying to come up with a solution to use my Tuff Wheel on my 79 300 with Tilt and haven't found a solution yet.
On my '77 with tilt column. This is a grant 3196 install kit and then i added a 3 to 5/6 bolt adapter from amazon.
Great job Casey! However I need one that works with tilt and telescoping column
I have a column from a 72 Imperial that I wanted to try to fit in my Satellite. If I remember correctly the Grant adapter will fit on the column but the trouble is fitting the horn button and telescope lever. I used a Grant Challenger dual plane and notched the spacer between the 2 planes for the lever to stick through. Figured I'd have to make a plate to cover the center and mount the horn button to it, but I've abandoned that project.
