Super bee hood scoop placement
greenmachine
4:57 AM
portland
Hi guys
I am getting close to having the bee clone painted (in PGE green with envy!) and opened my twin hood scoop box from PG classics to lay out the template. The problem I have is the template gives no orientation where the template for the holes should sit on the hood in relation to the sides, front, and back edges of the hood. The template just has the holes for the scoop studs and the rectangular hole where the ramcharger ducting would attach under the hood. Can anyone tell me how far from the side of the hood the scoop should sit? Also, how far from the back (windshield side) of the hood the edge of the scoop should sit? Thanks guys.
On the scoops on my Swinger the bottom of the hood had 1" holes from the factory on the bottom side, and I just took a hole saw and the center bit was where the scoops mounted. It just had part of them but enough I got the lay out for them. Maybe it will be the same on yours. Good Luck with it. Ronnie
