:headbang: I really think there would be alot of modification .the good thing is there is alot of company's out there that make parts for the 73 -74 .I would see if you can get a plastic molded engine for mock up .use a 727 trans cause it will bolt up to the new style HEMI.There are a few things to look at steering is going to be the first problem with the rear steer . I definitely like idea of this swap but it will take alot of homework .Call tti to see if they would take the challenge of making the headers for the application . The eaisest route would be to put in a o'rielly k member which gives you more clearance ,BUT ,it might open pandora's box for something else .....good luck .........
