swap to power steering
peakandscoot
9:11 PM
Clearwater FL
I have a 62 Fury with a 383 and would like to convert to power steering what is my best option and are there any problems associated with doing this if any.
you will need a power steering pump,hoses,belts,power steering box and power steering pitman Arm. You will need a column from a power steering car, as it is shorter then the manual or you can cut the manual steering column down to the size needed. I have seen it cut down a few times and it works with no problems the guys tell me. It will add 80-90 lbs to the front of the car
