Tie rods and sleeves
Kern Dog
Life is full of turns. Build your car to handle.
7:52 PM
Granite Bay CA
I should know this but here goes...
When installing an inner and outer tie rod end and the adjusting sleeve, which end attaches to the center link? The RH or LH threaded tie rod?
I have my engine, trans, K member and everything out and am putting it all back together soon. I cleaned up all the parts but forgot to mark them for orientation.
My bonehead guess is that it doesn't matter but I wanted to make sure.
Put the tie rods together side by side. Do you see any difference ?
Therein lies the issue. One side is slightly longer than the other. I can probably look at my pictures and figure it out.
As long as the steering gets full travel left to right, it probably doesn't make any difference. The alignment guy just rotates the sleeves to set the toe and doesn't care if it has to rotate CW or CCW.
Looking at your photo (Nice sway bar) it looks like the LH thread is on the outboard side.
It does matter, if you are. Replacing one you need the correct threads. The only difference between inner and outer is the LH or RH threads on them.
look at the listing, LH threads are inners.
Thanks guys....I LOVE learning new things.
It is a funny thing....I've worked on the 64-89 RWD Mopars for years and still have much to learn.
In theory, I agree. My tires rub the frame rails before the steering box reaches it's full travel for either side.
I discovered mine do also just this last weekend with the front brake work I did - and they're just 15x7 Magnums
with 235/70's on them. Rims could use another 1/2" offset to the outside methinks...
Then you have to watch for the tire rubbing the front corner of the fender, better off having it hit the frame rail.
