Terry1213
I bought a 1964 Polara 383/727 with a 8 3/4 rear. Everything had been rebuilt but I went thru it all anyway. The brakes were my latest project. The front were fine but the rear were not. In 64 the 8 3/4 had press fit hubs. They also swaged the drum to the hub so you need a puller to remove them. The drums were replaced but they did a bad job of mating them to the hub. I didn't get pictures of that. The drums were not flush on the hubs so they were wobbling. The stud holes were bent out. In the picture you can see the swaged stud and there is one that is not. Left hand thread so maybe it was snapped off. Two ways to fix this. I opened up the holes on the drum to fit over the swaged studs. You could also remove the swaged studs and get new ones, but you can't just pound out the old ones because that could damage the hub. A special cutting bit is required.
Leaving the hubs pressed on and bolted makes it like a modern rear end. Just pull off the drums. I know it's a long story but I went all over town to find someone that could swage like the factory did. No luck. I understand the reason the factory did this was for ease of assembly on the line. Hopes this helps someone else.
