FOR SALE Top Cat Window Felts
69bfan
FBBO Vendor
FBBO Sponsor
12:43 PM
Jasper, GA.
Feedback: 8 / 0 / 0
The Top Cat window felts are considered by most as the most correct and best fitting window felts on the market. I have the various styles available for $95.00 for the 70 and earlier B-Body applications. These are the eight piece kits. Kits for the 71 to 74 B-Body applications are $150.
Just drop me a message for specific pricing. Kits are shipped from zip 30143. I do not take Pay Pal.
I'd like to see the 73/74 products.
I'll need inners and outers eventually.
I looked at my friends E body repro felts and they are nothing like my 73 Satellite.
Totally, and I mean TOTALLY different design.
These felts are brand new. Each style is correct for that particular model year and body style. These felts do not use the hard rubber sweeper material found on some of the lesser quality reproductions. They also utilize the correct attaching hardware for the particular year model and body style. I will post some pictures of the various materials used later this evening.
Here are the pictures of the 66-67 B-Body application. The piece in the center is the felt that attaches with staples. Factory style staples are included, but some shops use tiny screws or rivets. This would be for the inner quarter felts. The doors use what we refer to as the finger clips and the outer quarters use the style as used on the 66-70 B-Body hood to cowl seals.
The 68-70 B-Body application for the hardtops uses the same outer material and uses the finger style clips for the doors and outer quarters. Inner quarter felts are attached with staples or with rivets or screws, depending upon which you feel most comfortable with. The inners on the 68-70 B-Bodies used a heavier flocked material and that is where it differs from the 66-67 felts.
As stated in the original posting, each style duplicates the factory originals as close to as possible in both material and attaching methods.
Here is a side view of the material. It is a flocked rubber material like the originals. Some of the reproductions are just a hard rubber lip that ends up pressing against the glass. This can end up scratching the glass, wrinkling up as the glass goes up and down and putting pressure on the glass which makes it more difficult to raise or lower the glass.
Are they available for a 70 Satellite convertible?
The 69 to 70 Plymouth B-Body convertible felts are available. They are much different than the hardtops in that the inner bright bead is much wider. Also, the 68s are a one year only and Dodge and Plymouth are different. So it does make a difference in getting the correct pieces for the particular application.
Attached is pictures of the smaller bright bead used on the majority of the felts from 62 through 74. Some applications used a black bead, some used a cloth covered bead and some were rubber coated. There is also the wider interior bead as found on the 68 to 70 Chargers, convertibles and some of the 64 to 65 applications.
Just let me know when your ready to order as I have the kits made up. Most everything is in stock except for some of the more odd stuff like a 63 C-Body four door hardtop. Those kits are made up as the orders are received.
I'm ready now. I will need to mail you a postal money order though.
Ghostrider, I just sent you a private message.
Thanks,
Richard
Can you list out what pieces are included for the 67 Coronet?
Ty
Ty,
The 66-67 B-Body felts are the same for both the Dodge Coronet and Plymouth Satellite applications. For a kit, it will consist of eight pieces. This will be four outer felts, one for each door and one for each quarter glass. Then you will also be getting four inner felts. Again, this will be one for each door and one for each inner quarter glass.
All of the felts will include the proper attaching hardware as used for the particular application. Also, unlike the cheaper and incorrect felts that are available, these incorporate the same style of material as the factory original pieces used.
If any questions, just drop me a message.
Thanks,
Richard
Ty,
Thanks,
Richard
Thanks Richard, my name is Mike, Ty was thank you. Lol!
I will purchase a set, when Mario the Meat Man makes a recomendation, I feel I would be letting him down if I didnt listen...
Do you have the channel runs by any chance?
PM me with payment instructions.
Mike,
Sorry about the confusion. Are you needing the felts for a 67 B-Body sedan with a post or is it a hardtop? The reason that I ask is that I do offer the glass channel run as used in the sedan applications. These kits are $120. For the hardtop applications, the only channel run is the piece that attaches to the front leading edge of the door glass and moves inside the stainless track for the vent window frame. For those pieces, they are $200 per pair for the OEM pieces are $95 per pair for the reproductions. The channel run that is known as the lockside channel is no longer available. Hope that this will answer your question.
I will shoot you a message as well concerning payment and shipping methods.
Thanks,
Richard
