Tranny pan gasket 727
Nick ciavarino
6:32 AM
New castle pa
What would be the correct torque for the pan gasket using the silicone one by real gaskets.Thanks Nick
With a "short grip"3/8 ratchet (just past the ratchet head) pull till it feels good & tight. Never had leaks, both rubber & cork gaskets. Don't over tighten.
Do you have a FSM/Factory Service Manual? If so the specifications are listed in that section if that is your preferred spec. Otherwise as stated above will also do the trick. Just do not over tighten...cr8crshr/Bill:usflag::usflag::usflag:
With the 1/8" silicone gaskets they'll never feel tight. Torque them to 20 in. lbs. one time only, don't go around a second time.
