Trans not kicking down/Bouchillon KDC
69'Net
11:32 PM
Texas
I have a Bouchillon kickdown cable on my 727/440 with holley avenger carb. I'm fairly certain I have everything installed correctly. The trans doesnt kick down unless I come to a complete stop. I currently have the valve lever completely open with full throttle on the carb. I tried it at eighth inch increments looser as well. Still nothing. What am I doing wrong? The transmission was just completely rebuilt.
sounds like a problem inside the trans, the tighter the cable the higher the rpm shift points
Does the kick down lever move with the throttle? If you crack the throttle, the KD should move too. If it doesn't, you'll have problems with shifting correctly.
Yes, they move together when I crack the throttle. After messing with it last night I decided to open the throttle all the way up and move the kick down back as tight as I could get it (making the valve lever bottom out almost before I'm at full throttle). It will now kick down into second when I stab the throttle at cruising speed. It still don't feel it down shifts like it should though when I casually slow down. If I slow down under 25 mph, it will stay in third unless I come to a complete stop. Maybe that's normal I don't know? I hope its not the trans, I had it rebuilt by a shop almost 6 months before I put my engine in.
