4eyedblonde
How do you remove the front turn signal bulb on a '64? I twisted n pulled, pryed...I don't want to break this. Thought it would be straight forward
If it's anything like mine was it was super corroded. I broke the bulb then used a long nose pliers to pull the base out. This was after I blasted it with penetrating oil. The other side was a different story the base was corroded and I wound up replacing the socket too.
