Turn Signal Lever Screw?
dodge68charger
6:21 AM
Washington
Does Anyone Know The Size Of The Turn Signal Lever Screw on A 1969
B Body or a Source?
Can't tell you exactly what size it is but approx. 1 1/2" long and I believe fine threads and around 1/8"dia. I've replaced that turn signal switch once about 4-5 years ago. I looked at my fsm and can't find any reference to it's size. Youtube'd a guy replacing a switch assy and caught a quick glance as he removed that screw. You may have to buy a few screws around those dimensions to fit. When you do find a replacement be sure to use the blue thread locker to keep it tight. Good luck.
The screw also has a rounded end with no threads for the first 1/16" approx., to help guide it through. I don't think you'll find it at the hardware store. I will need one too eventually.
I may have one. will ck tonite when I get home
