U joints for dana versus 8 3/4
Ralph Cali
4:39 PM
NJ
I have a driveshaft with a Mopar 7290 u joint and will be getting a dana rear end with a 1350 series pinion yoke.
How do I mate these up correctly
Do I just buy a 1350 u joint and have it pressed in ? how do you install and will it fit ?
Thanks for the help as usual..
ralph
you can buy a combo universal joints
you will need the width of both and the cup diameter
You could get a special joint, or have a 1350 series end put on your shaft.
Where in Jersey are you?
Buy only Dana Spicer Quality, Call DTS for the part. Mate up a true 1350 Joint. The Dana Spicer is still 3x better than off brand product.
Hey guys thanks for all the good information
I am in central jersey near the englishtown racetrack
Sounds like the best way to go is have a 1350 put on my current driveshaft since the dana is longer than the 8 3/4 and I may need to have it cut down
how much space should I leave so the I have some play in the system, meaning after measuring the correct dimensions between the yoke and back of the trany example make 1 inch shorter ?
Ralph
You will definitely need to have your driveshaft shortened. Its been a long time since I had mine done but iirc it was 2 to 2.5 inches maybe. Had 1350 joints done at both ends. Only makes sense.
I just got a complete TKO tranny kit (tranny, shaft, etc) out of 68 RR (Dana rear) and the driveshaft length was only 1/2" short on my 8 3/4" and I used the mentioned universal joint to mate the two.
Difference 8 3/4 and dana
Ralph
I am not sure exactly what car you are working on but, this would work for all applications.
This should give you the right length difference 8 3/4 [51.50"] and dana [50.39"] which would make the shaft 1.11" shorter with a dana. So regardless the length that would be the difference.
Information is from 69 parts book and the specs are for a 69 RR or GTX.
Jeff
Hello,
I'm also putting a dana under my 62 Dart. It has a 8 1/4 under it know. So will the drive shaft work with the dana?
Driveshaft
Hello,
As you can see in the chart there is 1.78" difference between the dana and the 8 1/4.
If it has a 8 1/4 then just shorten the 1.78".
Make sure you use the proper u-joint.
The measurement [c] is taken from the housing tube center line to the pinion housing as in the chart.
http://www.ringpinion.com/b2c/ProductDetails.aspx?ProdID=6546&Product=DS_U-3140&Brand=Dana_Spicer
http://www.doctordiff.com/1350-to-7290-conversion-u-joint.html
as said earlier, have a driveshaft/clutch shop shorten the shaft and at that point put on the 1350 series yoke. If it were me, (and you can afford it) I would have the front changed also. No sense in having a small diameter, lighter duty u-joint in a heavy duty setup.
