uca bushing
ddpsnake
12:12 AM
Belleville Canada
Still have this dam pop,or creaking going on,have torque the bolts to 85 ,so my question is do i have to support the lower controls arm to remove the uca bolts.and have a look at them.71 satellite
It easier if you support the lower control arm, otherwise its pulled down onto the rebound bumper. Use a floor jack and lift it enough so the upper is not loaded.
As Miller says, after remove the wheel and put a jack under the spindle and raise it up a bit so it's not being pulled down too much.
Mine also squeaked a bit in the beginning, did some final adjustments tightened them up tight...never heard a squeak since.
