FOR SALE Upper control arms w/Moog offset bushings, idler arm, LH lower ball joint
cudak888
11:56 PM
South Florida
Feedback: +4 / =0 / -0
This is what you call "leftovers from a change in plans." More pictures below, but first, here's the rundown on the lot:
  • The upper control arms are originals, just out of a dip - the silver areas are bare metal (they'll probably have a bit of surface rust once they arrive). Ball joint threads are good; I removed the originals with a proper wrench and didn't bash them out like an idiot. All the bushings will need to be replaced.
  • One set (only enough for one side) of offset Moog bushings. Brand new.
  • One standard-length B/E body AC Delco idler arm. New. Removed from the plastic bag, and that's it.
  • One B/E body left lower ball joint/steering knuckle. This part is new, but it has slightly gacked threads. If you run a tap on it, you'll be good to go.
$150 for all + $16 shipping USPS Priority.
-Kurt
