upper radiator hose for 32inch wide radiator
lxmodguy
Gen3 Hemi Guru
5:21 AM
Texas
I went with a griffin 32 inch wide radiator in my car to try to keep the car cool in the Texas heat. I was wondering if anyone else had done the same and might know a upper radiator hose part number. The stock hose is about 4 inches short. it needs to move towards the passengers fender and towards the front of the car a bit to work.
Part number anyone??
I dont have a part number but I used one from an older 70s dodge truck. Or you can cut the hose where it is straight and put in a peice of exhaust tubing to extend it. I would put a flange on both ends for extra insurance so the hose dont slide off.
I used one of the side exit t-stat housings, and went to Autozone with the lengths for each side of the hose, and looked for one with a slightly more than 90 degree angle. I don't know what it fits, but the number on the hose is Dayco 70344, and it was long enough that I still had to cut it to fit. I have a 26" aluminum radiator with the upper hose on the passenger side.
