Vehical won't shut off with key
joseph44
11:18 AM
lancaster s c
Hi Everyone new here 1st mopar . I purchased a 73 satilite clone r r satilte r r barn find Question: The car stays hot to shut down I remove the hot battery cable,I replaced the starter relay no help, I was told the ignition switch was bad replaced no help. The only thing I can come up with is wiring from starter to to starter relay. By chance does anyone have a schematic for wiring from starter to starter relay? Any help would be greatly appreciated. Thanks to all.
Do you mean the car continues to run after key is turned off. I don't mean dieseling.
Ballast or coil or related wiring is being feeded straight from batt/alt. It can be anywhere into the wiring system, from inside the cab up to engine harness.
It can be either a wiring "short" ( melted wires making contact with the charging system wiring ) or some jumper wire around made for emergency.
My bid is on bulkhead... melted wires and bulkhead ( very common Mopar failure ) made contact between them. Specifically alt black wire and blue run circuit.
Starter relay has nothing to do with ignition. Just wired to crank engine. Even getting a short wouldn't feed the ignition system, just keeping cranking the starter motor
Indeed. As long as the ignition circuit gets juice, whatever way, it's active.
