Volt meter in dash
Cornpatch MO
12:06 PM
Southwest Iowa
1964 B body Dodge. I want to dis- connect my amp meter and put a volt meter in the instrument panel where a clock would go. ( I do not have a clock) Anyone have pics and info on how to do that and make it look good? Size of guage? Can it be done without taking the instrument panel out? Thanks for any help........................MO
I believe that a standard size gauge (2 5/8") will fit but you will have to remove the cluster and take the bezel off to cut lens out! The gauge will slide in the bezel from the front of the bezel. Use a gauge with a chrome trim ring, it will match the rest of the bezel! You might have to cut the back of the housing so the bezel will mount correctly!
