WTB WANTED: roof rail or maybe a donor roof / Dodge Charger 73
Stagepirat
1:38 PM
Munich, Germany
Hello everybody.
I changed my 73er Charger from a SE to a Rally. So now I´m missing a part of the roof rail where the molding is attached. I builded something myself, but I´m not to happy with the result.
So I someone has an old roof (the condition does´t matter to much) maybe you can cut out the roof rail part I´m missing.
Thanks in advance
Axel
you need the passenger side drip rail ?
i have to go look at the roof i have
but i can't make any promises
it has sat outside for a while just laying up against the garage
and it was headed for scrap as it has a few holes in it.
give me a few days to get back to you
when i can get over to look at it and see if its worth something you could use.
Hello.
I would need both sides. Not only the passenger side.
i didn't forget you
here is the victim..
the drip rails aren't dented or rotted out
just the roof was cut off before the cowl so the whole rail isn't there in the front
you can see in the pic
it had some rot in the rear window channel so it was heading for scrap
but i don't throw any bits out until the cars are done ..
it has sat there a few years
in case something is ever needed.
you should be able to get a good patch out of what i have
shipping the thing to you would be crazy
i would think
but i can cut whatever section you want
Hello.
Sorry that it took me so long to answer, but I was on work nearly 24/7 the last weeks. I think you have exactly what I was looking for. Could you cut out the drip-rail sections on both sides? In case just cut a little more, so it does´t bend so easy during the transport. Maybe the parts will fit in a cardboard-roll? I know it will be easy to pack it.... But of course I will pay you the costs.
Greetings Axel
I'm a working guy also so I fully understand
I can slice and dice it any way you need
just let me know where you want it cut
your circled pic? or even the length of the whole thing?
i can find something to ship,
i could even use a pvc pipe if needed as long as the piece is straight.
just let me know the specifics
and it will take me a few days at least to get it all together, cut it up and pack
after i know what is up.
Frank
Hello.
Would it be possible, that you send me your mail-adress, so I could send you the pictures of the parts I would need.
Thank you
Axel
check your inbox
I started a conversation
and my email is in the message
Frank
