wantahemi
So I took the 440 Six Barrel out for quick cruise since there was no snow on the ground or roads in Upstate NY in December. Anyway, was cruising and decided to open it up a little. Upon hitting the gas, I started to hear a nasty rubbing / clanging noise. Pulled over and water pump pulley was wedged / misaligned. After some roadside disassembly and a $135.00 flat bed ride home, I found what you see in the pics. The center of the water pump pulley just broke out.
I found a shim behind the pulley which appears to have caused the pulley to break out. ALSO, the water pump bolts were rubbing on the back of the pulley. Obviously clearance is an issue. So since I was lucky enough to not loose the fan, belt or experience any damage other than the pulley, its not going back together until I figure out how to make it PERFECT. So my questions are:
1) I have heard about a milled water pump or housing, does this work and where can I buy it.
2) The water pump was replaced about 2,000 miles ago by a local guy and I am assuming the shim was his clearance solution. Why would I need to shim anything? Seems like a problem
3) Any other suggestions would be appreciated. Prior to replacing water pump, never an issue!!!!
Thanks in advance AGAIN!!!!
Al
Al
