what lower hose did you use
1967GTXhemi
New Member
8:01 AM
louisville, ky
i have a 5.7 hemi in my 67 gtx and i am using a couple of hoses with a metal tube in between them but it is beginning to leak does anyone know of a rubber hose that will fit this swap without cutting or combining two different hoses thanks
I put a 65 Polara 383 radiator into my 72 slanty Dart, and the lower connection was the opposite side, so I did the same thing.
Worked perfectly. The connector must still be waiting to rust through.
It was worse on the 66, where I put in a replacement radiator that had the upper tube in the wrong place for 66 Ply, and I had to eyeball a replacement hose.
Finally got the upper end outlet moved over to the correct spot, so the called out hose fits and it's factory again.
