what pitman arm do I need?
davek
7:32 PM
columbia SC
changing over to ps so what do I measure? I believe there are 2 different ones. Do I measure the shaft size where the pitman are bolts to? I think the box is from a 73 car.I havent put the steering box in yet. Installing on 70 Bee thanks for any help.
There are 2 an 1 1/8th and a 1 1/4 If you previously had manual steering its possible that its the 1 1/8th You have to measure the steering gear that you are installing. Should be an 1 1/4. But I guess its possible to be the 1 1/8th. Measure the part where the pitman arm attaches.
thank you Beep Beep RR
