What studs do I need to mount six pack carbs ?
chucklbunny
2:14 AM
Massachusetts - Where EVERYTHING is illegal !!
Hi Everyone !
I have a question for you guys, what studs do I need to mount six pack carbs to the intake ? I want studs instead of bolts so if I have to remove carbs to adjust them I won't strip out the threads in the intake....can you guys help me find the correct set? this is for my 72 satellite/RR clone with a 440 in it.
thanks !
Chuck
A little anti-sieze and you won't have to worry about stripped bolts. Actually, if the threads are clean and in good shape, you shouldn't have any issues without anti-sieze.
Basic auto parts store carburetor studs work just fine. They're usually in the "shiny chrome race stuff" section.
And a word of advice,don't use washers !
Curious, why?
Chrysler "never" used washers on carburetor studs or bolts,over time they can work loose,an extra contact surface you don't need.
I use washers on my x ram Holleys. Silly to put washers but never had a problem. They come off at least once a year, spring to check torque on bolts. Don't want bolts rolling around in pelenum chamber.
