What transmission in 05 Hemi
Dreamcatcher
Will fish for food
3:48 PM
Keystone,S.D.
What transmission would be in an 05 magnum that has the 5.7 hemi? I have an opportunity to buy an 05 magnum that had a dash fire. It has a 5.7 with 70000 miles. Just wondering if the transmission would be the 545 or the nag? Owner didn't know.
Doable, but there are "headaches". If you want a 5 speed auto, I'd use the 545rfe trans from a 2wd. truck. You will still have tunnel mods and cross member mods, but the trans will run out of the box. You could also use the small block 727 and put a Gear Vendors on it and now you have a 6 speed.
Thanks guys. Yes I knew about all the body mods. I was going to do a 68 with a 03 truck hemi but changed my mind and sold both. But still kicking it around as I have a couple more chargers and I still have one badly wrecked 03 hemi truck left. I just think the car engines look so much cooler. And I thought the 05 would be better than the 03. They might be the same but thought the 05 might be a better choice. Rambling here I guess but I usually buy these hemi 's when they come up. This one has only 70000 miles on it. I could have the whole 05 magnum for 2K . It had a fire under the dash but just some melted wiring.
